Doors lock after unlocking if keys not put in ignition
Cruz69
Cruz69
Hove
T5 SE 174
When I unlock and open the drivers door, if I don t switch on the ignition, the van tries to lock again after approx 15 seconds, then the alarm will trigger if I don't hit unlock again. Faulty drivers door lock do you think? Any ideas / thoughts gratefully received. thanks
Does the door show as open on the screen? Faulty door sensor perhaps?
Faulty definitely, as above does door show open etc
Most likely the lock mechanism not necessarily the drivers door !
How old is the Van ? Warranty?
When you lock the Van does the red LED on the drivers door flash rapidly for about six turns then go straight into the intermittent flash ?
If not there is an issue with the lock - search my other posts for further info (I’m away ATM)
to test : Lock the van whilst you are in it , can you open the doors (all of them) , if so the one you can open is probably the faulty lock
Hi. Van is a 2009. No warranty any more. I will do some investigation this weekend. It does seem as though it seems to revolve around the drivers door. Open the sliding door and passenger door, van doesn’t seem to misbehave.
As well as the Red flashing LED on drivers door , When you open the doors individually does the Hazard button illuminate? ( opening each door should illuminate the hazard button, even the slider) I would suspect a faulty lock is causing the issue.
Do you know anyone with VCDS tool or search tinternet , usually someone local will be advertising their VCDS for hire or a VAG Indi specialist will have the Diagnostic tools required.
Good luck report back to help others
Somewhere you can set it to random lock. It will do it anyway . It does what it wants. I always have the key on me and keep one in a lockbox attached to the bike rack.
Update. After reading your comments, (many thanks for them,) I have come up with the following. LED on the dash notifying there is a door open will only light up when rear doors, sliding door or passenger door is open. It does not read the drivers door as being open. This seems to point to the door contact for the drivers door being faulty. Am I correct in saying this is a complete door lock / latch mech change? I believe the read contacts are in the latch aren't they? Unlike older vehicles that had a separate PIN switch in the door.
This is now understandable why the van tries to lock itself if only the drivers door is opened as it doesn't see that a door has been opened.
Complete door lock, doesn’t have to be from a VW Dealer £££££ VW OEM locks do fail (I’ve had several VW vans and multiple locks fail)
Motor factors or Tinternet if you can change it yourself if not local garage (easy job )
Edit :
Edit : link added (I have no experience of this product or company, it’s just for info DYOR)
Read instructions as it is supposed to lock if keys not put in ignition.
My Cali has done this from new and was warned about it by dealer,
Yes, I was locked out of mine with the keys inside, whilst out camping, luckily the pop top was up, so I ran a byro pen through the zip on the front of the pop top, climbed in retrieved the keys then ran the zip back over again. The AA man wanted to prize my door open
The door should not auto lock if the van is unlocked via the Fob & the drivers door has been opened (no need to put keys in ignition ) if your van does re lock after opening the drivers door it's faulty.
The auto re lock is designed to prevent security issues if the van has been unlocked but no door opened
There are many reports of people being locked out when the van "re locks" but this should not happen by design (if the drivers door has been opened ) , it appears to be a random act sometimes.
The internal lock on the drivers door, used to lock the van, whilst in the van, etc will re lock the doors if you close the door, which can cause a lock out and this is by design to prevent unauthorised access from outside whilst you are in the van (sleeping), it also disables the internal movement sensor for the alarm
L
5K
Kidz147
Kidz147
Kenb17
Meoncoast
Meoncoast
5K
camper-x
Trollhunter
Trollhunter
Trollhunter
BigJohn
