Constant active water pump
Truman
Truman
Manchester
T6.1 Ocean 204 4 motion
My Water pump is constantly whirring, Tap seems to be just fine. Anybody come across this issue before?
I've disconnected the pump itself as my batteries were dead. Could this be a tap issue?
My guess would be that the contacts of the micro switch in the tap have arced and welded themselves together.
I and others have made a modification by adding a relay to the tap circuit to reduce the current through the tap.
Good morning folks.
I disconnected the pump and reconnected now it’s decided not to work at all.
I removed the handle and microswitch and it fell apart. :rolleyes: After successfully re inserting the switch parts, I must have assembled it wrong as the handle tore it apart. Now sadly it’s broken the contacts.
All I can think about is it started randomly and continued until the batteries ran out, how long must that have been:shocked
So we’re off to sunny Latham today. Bottled water for us, and tap reassembled but not as much as to easily remove for the new switch.
Hopefully it’s just a fuse, and not the pump itself.
Thanks for your replies
