We have the same, 6 months old vanHelp !
Currently away and the left hand cupboard latch appears to have cracked..
Where can I get a replacement? Is this a warranty item, they don't seem particularly robust.
D
As someone else pointed out it's a poor design, the right hand door slides to the fully open position and hits the left hand latch on the inside and cracks the plastic.Strange phenomenon, mine has just cracked. 6 months old.
The latch on the other side just broke off. Presumably still a warranty replacement but I haven't contacted my guy yet.Mine was replaced under warranty, with the statement that it happens a lot.
If you take this route, rather than a brace as in #8, I think you will two stops, one for each door, for optimum protection. It could be a neater and simpler solution than the brace I fitted, so I am interested how it works in practice. Perhaps a top and bottom stop each side will be even better, only a trial will tell.As someone else pointed out it's a poor design, the right hand door slides to the fully open position and hits the left hand latch on the inside and cracks the plastic.
When my latch is replaced by VW next week I will install a stop in the bottom runner to prevent it happening again, I'll put a post up with a photo once done.
Useful comments thanks, I've checked there is adequate clearance for the stop in the runner while still allowing the drawer to open., I'll provide a reference dimension for the stop. I'll consider a second stop as you suggest.If you take this route, rather than a brace as in #8, I think you will two stops, one for each door, for optimum protection. It could be a neater and simpler solution than the brace I fitted, so I am interested how it works in practice. Perhaps a top and bottom stop each side will be even better, only a trial will tell.
I look foward to your photo. I think a previous poster used a dome head screw as a stop, but there are lots of epoxy based possibilities too.
There is limited tolerance between stopping short of the latch and leaving space for the undersink drawer to open, though I am probably stating the obvious.
You are quite right @sbmcd it is a poor design to the extent that the stops are inadequate (but this is easily remedied), in all other respects I think the kitchen cabinet design is excellent and better than any alternative I have seen.
It also might be worth looking at reinforcing the 'tongue' at the LH door frame/keep.
I think the LH door 'slamming' onto the RH door is as much of a risk to the latch(es) as RH to LH, but I think from your post that you think the same. Additional top of rail stops might be a luxury, but this you will likely discover once to start the fix.Useful comments thanks, I've checked there is adequate clearance for the stop in the runner while still allowing the drawer to open., I'll provide a reference dimension for the stop. I'll consider a second stop as you suggest.
I think 10mm aluminium square rod such as below might be alternative, with soft rubber trimmed to the impact edge.Here is my solution, 10 mm OD neoprene hose as the "soft" stops, it's fuel hose I use on my motorcycles. It fits nicely into the cupboard door tracks which are slightly narrower.
24.5 mm long for LHS and 27.5 mm long for RHS, would probably work without adhesive but I'll add a dab of super glue.
That is interesting, and will certainly avoid excessive pressure to open the latch and ease engagement, but if you feel behind the latch when the opposite door is fully open you will find the door strikes the back of the latch. I believe that is the root cause of the cracking.The problem with this latch, in my experience, is it over-engages in the door frame. This over engagement forces the user to press too firmly which results in it breaking.
Simple fix. File down the height of the ramp on the latch.
You can see here, I’ve filed a flat on the top of the ramp.
Do it bit by bit till the engagement/operation improves.
Good luck... I asked and my dealer said it had to be booked in, assessed a report written and sent to VW first !Off to VW today see if they will just give me the latch under warranty, fit it myself
no chance - i asked em to post it me so to fit due to time / effort to get to dealer...Off to VW today see if they will just give me the latch under warranty, fit it myself
Unlikely. See post #37 above.Had the latch replaced under warranty.
So when i got Dizzy home, took it off (looks like 2mm allen key), glued on the 3d printed reinforcement and popped it back in...
fingers crossed this lasts.
