T7 California welcome
T7 Ocean hybrid.
Working through user guide have realised there are a couple of questions we should have asked at handover "hayho" ‍♀️‍♀️
Have worked out how to save battery usage.
But air con in rear not coming through very cold or fast.
On the rear control panel it says its been deactivated in infotainment ? ?
Can't see/find where.??
Anyone already sussed this out please
T7 Ocean hybrid.
We've worked it out - feel such dimwits lol
Petrol phew.
Are they supposed to come with remote for parking heater ?
We didn't get one.
Van was from stock build.
  • Wow
Reactions: Sad
Petrol phew.
We didn't get one.
Would be interested in this too, as I’ll be collecting a new ocean in 4 weeks hopefully
Petrol phew.
We didn't get one.
Is it a Paid for Option? If so may not be on a Stock build.
Hi (again)
Still going through bits & bobs.
Whilst sitting in Victor trying out the My Volkswagon app (this allows you to control system use on wifi signal via phone) & California Volkswagon Vanlife app (Bluetooth connection) the cupboard lights seemed periodically flash ? ?
Petrol phew.
We didn't get one.
There seems to be a few options that you cannot necessarily chose in the configurator.
I got one parking heating remote - it seems to have a limited range and I wouldn’t miss it if I didn’t have it.
Fly screens for the windows in the sliding doors however …… I think like many owners they haven’t appeared yet.
Try touching the remote to your forehead when pressing the button. Range increased.
Well that was a shock - everything from the 6.1 Ocean has gone into the T7 Ocean.
We even realised "yet again" that we'd been taking a few too many 'Just incase buts n bobs'.
Just a few things to double check on electrical side and will be going off somewhere for just a couple of nights then Oban & Inverness end of the month.
There is more storage than people think, it’s just in different places to the 6.1, and granted you do have to get a bit creative with your storage solutions
If we use a dashcam in hpev ocean plugging into 12v socket on dashboard - will power be taken from 12v battery or from electric side of things. ? ?
There's also a 12v in the boot.
Little confused as thought everything from front seats forward was separate from sockets in rear.
Sorry if I sound thick.
According to your Avatar information you have a T6 Ocean.
The T7 PHEV Ocean is the same base vehicle as the Multivan PHEV and the front 12v socket and USBc ports are powered by the 12 v Engine battery. I’m not sure about the rear 12v and USBc sockets as they are also present on the Multivan and powered by the engine battery.
Thanks for reply WelshGas - just a week ago moved from T6.1 over to T7 phev - have tried changing my avatar but not worked.
I’m pretty certain in will be the same as the rest of the range. Camping mode allows you to turn on the four rear usb c and they run from the leisure batteries.
12v socket in the front is powered from the starter battery the rear 12v socket is powered by the leisure batteries.
If you are thinking of powering a dashcam don’t forget you have USB C in the rear there is one in the right rear window frame and one in the rear cupboard you could use to power a rear facing camera.
T7 Phev Ocean 4 motion.
Having plugged cooler box into front dashboard 12v socket the small rear display unit shows that the 2nd battery (which we assume is the leisure battery ??) is changing voltage/drainage.
Vehicle battery voltage/drainage does not change.
Has anyone else monitored what drainage gets taken from where. ?
T7 hybrid owners.
Did you get your charging cable with your vehicle.
Ours was from stock and didn't come with one as dealer didn't tick the box ??
Just curious.
T7 hybrid owners.
Just curious.
I presume you mean the EV charging cable?
As far as I am aware all EVs and Hybrids come with the basic cable .
Have just seen on YouTube that VW Commercial have released some T7 Cali videos that people may find useful :thumb
Admit we've taken the Chairs out of the boot (even tho slightly more comfortable than those that came in T6/T6.1) but as we've never used the chairs from previous 2 vans - we purchased a couple of other collapsing chairs we've found comfortable.
