Closing Roof problem
Southcoastcali
Hiya clever ones. We have a 10 plate t5 which we love to death. Putting roof down yesterday mid lower it asked me to switch ignition on ( was already on) so I turned off and on and then it continued to lower for another couple of seconds, repeated a few times until properly down ( heard the “noise”) but then flashing roof open symbol. Any ideas what is going on?
Hi, yes happened twice again. Good shout though on the control panel codes. Will check that out
Thank you
I would check the roof pump fluid level, the fact the pump is running on without the button pressed means it has seen the closed sensors and is monitoring the pump current to see that the pump has hit peak pressure. If it doesn’t see the current peak after a period it will flag an error. Low fluid level can mean the pump isn’t able to reach peak pressure.
satellite
Julie and Archie
Julie and Archie
Julie and Archie
Nick S
5K
Skylark2.0
Skylark2.0
Scootinthesmoke11
