Little owl1963
Has Any one Got a diagram for what each fuse is for on the California Ocean T6.1 please.
Have you checked the Resources section of the Forum?Has Any one Got a diagram for what each fuse is for on the California Ocean T6.1 please.
Just use a Multimeter to check which fuses are live only with ignition On.Yes looked at resources , not a definitive diagram .
I want to install nextbase dash cam , need to either use 2 x Fuse taps or go into spare holders ?
Need a red VCC+ always on
Also ACC on yellow wire , only when ignition on .
Any idea best location within board to connect too ?
Surely someone on this forum has a detailed diagram ?
I will contact my dealer also
This post should help you locate switched and always on terminals for your dash cam installation.Yes looked at resources , not a definitive diagram .
This guide (scroll down to find fuse box C interior ) covers all fuse options (many of which will not be present in your vehicle)Thanks very usefull , the fuses you refer too any idea what things they control ? ?
Also looks to be lot spare fuse spaces in board , would it be better option go into a spare slot of its own ? If know the correct spare slot ?
