T5 fresh water tank is leaking
Surftanten
Sweden
T5 SE 140
Hi,
Our fresh water tank is leaking. It is dripping slowly from underneath the van. I have tried repositioning the level that closes the valve, but with no luck so seems to be something else than the valve. Will I be able to access the valve and the tank if I remove the shield under the van? Any other tips on what the problem could be or tricks on how to fix it would be much appreciated!
Thanks!
Karolina
Hi,
Thanks!
Karolina
I would suggest moving the tap lever vigoursly from full On to full Off 5 or 6 times with water in the tank before taking things further. I'm not sure if the tap mechanism is visible if the undershield is removed. I fear not.
Here is a diagram of the drainage system.
Thanks! I did remove the shield underneath, but you are right, it does not help much. I can see that it seems to be the valve that is leaking, but there is no way to replace it from underneath. I have tried to move the lever many times back and forth with no luck so far, but will try one more time before taking it to the shop.
I took of the lever to be able to turn it past the plastic stop on the tank, but there is no position where it closes completely.
