Lane keeping
sticky1
sticky1
Derbyshire
T7 ocean
Is anyone else noticing the lane keeping assistance being inconsistent?
On other cars I use the lane keeping steering intervention is cancelled when you indicate, unless there is another vehicle in close proximity.
However, the T7 seems to regularly intervene even if I’m indicating. The sensors on the T7 are very good and I’m not sure if it is picking up traffic further away than the lane I am entering but it would be good to know if I’m not alone seeing this issue.
Also is there an easy way to turn lane keeping off?
Not had that problem on the .ultimately.
Try top R button on L side of steering wheel?
Almost right. Bottom R button on steering wheel L hand switch panel.
Thank you, top right was speed limiter.
I’m still wondering what is causing it.
It’s not consistent, I came down and joined a dual carriageway and got a firm tug on the steering despite indicating and I didn’t see any vehicles close by.
Lane assist really grinds my gears.
The hardware & FW/SW is not up to a reliable standard yet.
So glad mine doesn’t have it. Whenever I drive my wife’s Tiguan it drives me nuts!
The best I've found is a Ford Mustang, the lane keeping button is on the end of the indicator stalk so when you indicate it switches off naturally...........ooohhh the V8 burble!
BMW seem to have it sorted too, however my V8 sounds like a sewing machine due to EU noise regulations!
I must admit on my Multivan I don't seem to have a problem apart from one section on the A48 where it consistently tells me to drive in the centre of the lane but at this point the lane markings have worn and are barely visible.
its a 5.3 with an active exhaust with four settings, the track setting is awesome!
