Beach Camper floor area
Kenb17
Kenb17
Basingstoke
T7 California Ocean 4 Motion
Can anyone advise the floor area of the Beach Camper with the seat in the sitting, back of area position? Considering a Beach Camper and one of the thoughts is getting bikes in (without front wheel). Many thanks, Ken
Not clear what you are asking? It’s possible to sit in the seat and get a full size large MTB inside wheels on, we manage 3 bikes in for the family of varying sizes, not sure what you mean by “back of area”?
Thanks for the reply and I need to try and clarify. I was thinking of the floor area between the seats accessed from the sliding door with the seats slid back. I have an arrangement in the car at the moment with the front wheel off and fork mounted on a bracket so it is shorter and stable in an upright position. I was thinking back wheel to kitchen and front wheel at door.
Gotcha now. I know my bike doesn’t fit. Just been and measured from fridge to closed door 1460mm. Seen some guys put roadbike with rear wheel between front seats and forks on a mount.
Have a look at the Vanessa arco system. Storage down one side and bikes down the other. Honestly I have found you can have a camper or you can have bikes inside but just not worth the frustration trying to do both. Good luck.
tbh it is not trivial in the car and it becomes a 2 seater.! Thanks for your help.
A change of approach to make it easier to carry bikes inside, removed the bench and use the 2 second row seats only. One seat pushed forwards and one bike with wheel off, second bike fitted between the seats.
If you don’t have the bench, have you thought about the VanEssa Arco system. Works with the single seats and has a split bed system. It’s quite flexible as you can do exactly what you have done in the photo but still have a single bed.
Edit: just read above and you already have seen it I think.
It is the plan to pick one up, had a great video call with them to check out how it works and will be ordering. Not cheap but seems to be the ideal solution. Can also be used with the bench seat, but we find for travelling being able to recline for rear passengers makes a difference.
I’d be very interested to see how it goes. I’ve had my eye on one for a while. They do a shortened bed for the Cali Beach so you can also fit an interior pod if you want to. The single pullout version has the most flexibility of course.
I’ve not spoken to them yet, but the video call you had was very decent of them. Would you collect from them? Probably avoid import duty that way, at least that’s what I was thinking.
I am based in Poland so I would drive over and collect. For me it’s the ideal especially as I have the pull out cooker which limits pods. I may drop in on the way back from Italy in 2 weeks time, otherwise it’s a dedicated trip. Already have the window bags so this would finish it off.
Chris who is the guy in the videos is happy to do a video tour, just drop them an email. I have to buy a smaller fridge to replace my current one so pushes the overall cost up, but still makes the most sense for what we do.
Ah I hadn’t realised your location. Yes makes sense to collect. If I buy one I would do the same even from the UK. Yes I think you need a 28L fridge, but with the single seat that folds very easily you should be able to access from inside as well. I look forward to some pics in the Cali once you have it all set up!
yes you can access the fridge from inside if you buy the slider, have to move the seat forwards, but you can then slide the fridge forwards…
Yes that’s what I was referring to with the fridge. In fact for me, that photo is how I would setup the van as I travel solo.
Bed permanently down on the far side, single chair and a pod… perfect for one! I carry a Brompton so don’t need such a large bike storage area.
Until the time comes to buy the Arco, I’ll keep tinkering with my setup inside the Beach :)
We've gone in this direction.
Ditched teh bench and sleep upstairs. Everything on this slider which is 1200mm deep. There is enough room for a single seat which we'll get at some pont and the area in teh middle of the van is still big enough to use the table.
I guess the rails in the van allow a narrower slider and the bed would go alongside... A Bromton probably fits in a large Eurocrate!
having just come back from Italy, couple of thoughts came up about the Arco. In high temps being able to keep the sliding door open makes sense, so led me back to either an awning room (plus small, fast easy to pack, minus: can’t be left on site) or a pop up like the popup hub (more work but can be left on site). Gives ability to have door open and emergency toilet in some degree of privacy which I have been told is a requirement.
With this setup, makes sense to throw a kitchen inside awning and then still use the internal stove for day trips and saves €4K Euro!
Hello| Too much luggage inside your Cali, and cannot install a roof box as this will not permit to enter inside lowered roof parkings? I found a solution for this with a vertical luggage box connected to a bike rack installed on the rear door of the Van. I carry quite a lot of things inside this vertical box, a portable kitchen and gas stove for cooking ouside at camping parks, table, table benches, beach chairs, a foldable ecologic and antisseptic camping toilet also built by myself. The vertical luggage box was built by myself too, using multibirch pads with maritime treatment covered by 4mm ppa pads for thermal and hydro insulation. Another great benefict is that we can sleep comfortable with plenty room downstairs free from a lot of things around and free from the portable toilet and chemicals odors. This vertical box is light weight (12 Kg approx), can easily be installed/remooved by one single person within a few minutes, so I can take it out everytime I want.
For any further question or more information, you are wellcome.
