Replacing the gas hose
Milly Molly
Milly Molly
Wetherby, UK
T6 Ocean 204
Hi everyone. I’ve had a look through the forums but not sure there is an answer to the query I have. Our gas hose from the bottle is out of date so needs replacing. Is this something we can do ourselves? If so, what about the hose that takes the gas through to the hob?
I’ve found the gas hose kit on Campervanbits but I’m worried about doing it ourselves with it being gas.
Thanks in advance.
Mandy
Thanks in advance.
Mandy
If you can wire a plug you can change the gas hose. The rest of the gas circuit is metal piping. Just like at home.
Yes, perfectly reasonable to DIY, I did it on our old 2008:
Is it easy to access the hose that runs through to the burners? or does that not need replacing? Is it just the hose that connects directly to the cylinder that I need to replace?
Unless your California is different there is no flexible hose to the burners. Just the hose from regulator to vehicle connection.
How old is your vehicle? those hoses have a 10yr lifespan in germany, only in order to get an Mot, they've now dropped that from the Mot tests so no more silver gas badge required. Meaning the hoses can now last longer.
It's a 2016 T6. So the only bit I have to worry about is the flexible hose from the regulator to the vehicle connection. Great news - thanks everyone!
Hi
I have just replaced our gas hose on our 2013 SE.
It was out of date so I ordered it at our local VW dealership. £29.
It's very easy to relace.
As for the rest of the gas pipework we got it inspected at a local a local caravan/motorhome dealership.
They said it passed no problem. (£70 charge)
For us it was piece of mind as the van is 12 years old.
I also just bought a carbon monoxide alarm for safety
Cwoods1405
5K
Hotel California
H
K
20K
The Fockers
T
PAPPA J
PAPPA J
