Will cascavel alloys from a 2018 fit a 2012?
DOMINICGG1234
DOMINICGG1234
Chichester
T5 SE 140
Hi
Sorry if this is a daft question but I have a 2012 se with cascavel alloys, but they are badly pitted.
I’ve had a quote to refurb but I’ve found a refurb Ed pair for sale cheaper. However, they are from a 2018 model.
The tyre size is identical but I have no idea if I need to check anything else (fitment?)
Any advice gratefully received
Before fitting the new set , give them a forensic clean and then a coating Gtechniq Ceramic wheel coating , its excellent at assisting in cleaning the wheels and resisting damage .
All transporter based vehicles T5 - T6.1 have the same PCD and fitment.
If you don't buy the refurbed Set, let me know the details :rolleyes:
To help other in future - Here is the detail to cross check for yourselves
As you can see T5 - T6.1 are identical for all models and variants
Note ; the annotation on the second photo shows year : Car model upto 2019 but the Title text says T6.1 2019 - 21 it should read T6 - I have added a forth photo showing 2015 T6 which confirms all are identical
Just to add this doesn't mean all T5-6.1 wheels are fully interchangeable due to different brake sizes on newer or higher powered Transporters.
Cascavel 17" Alloys though, will fit any T5.1 or T6 as stated above.
