VWGC side step issue.
K
Kenchadofmann
Guest User
Hi, 1st time poster here so please be kind :)
My step on my GC 600 has stopped working completely. I've taken the whole step off to bench test and found no issues with the unit. Everything is working as it should. Does anyone know where the fuse and solenoid are, its driving me mad trying to get any useful information. Bought the vehicle new 3 weeks ago !
TIA Ken
TIA Ken
Hi Ken,
Have you tried this reset?
Fixed a very similar problem for me.
And by the way the blue connector is under the glove box whether you have right- or left-hand drive.
(Click the link above - even though it looks like a general fuse layout thread, it'll take you to a post specifically about the step reset)
As above, need to reset the control module, big red switch off then remove the blue connector under the glove box. Wait a couple of mins, then plug back in. Hopefully that’ll do the trick.
Hi Ken,
Woooooo woooooo
Only gone and fixed it
Great advice. Thanks so much
thanks for this my step stopped after just 1 week and followed these steps with the blue connecter and boom all working again thanks .. james
TIA Ken
Hi went to start the van today and the battery was flat. VW breakdown confirmed the cause was due to a fault on the step.
Once the battery was charged it still wouldn’t work but there was a bussing from the plug on the step.
Apparently there is a TPI out for replacing the step should it become faulty, this has a different part code than the original. There’s also a software update for the Special Electronic Control Unit.
I’ve removed the step part of the unit to stop it sliding out and the plug has been detached and tie wrapped.
Just got to get the dealer to order the step; bugger!
Thank you for highlighting, useful information. Would be interesting to know what the SW update affects. Maybe will stop it freezing ..
Thanks again.
Will
Thanks again.
Will
My understanding is Breeze have carried out this step replacement and SW update recently on a GC and the initial reports back are it is much worse.
Hi Chris, had mine replaced last September as the original was faulty from day 1. The replacement has worked faultlessly since then. Interested in the SW update is for though.
Might have to have a rethink
Hello Everybody,
Bringing back the THULE step issue. In order to avoid any future headaches, I have removed the step from my 2024 GC600 right after getting the van from the dealership. Soon I have noticed that if the vehicle was not used for more than 3-4 weeks, it completely drain both batteries, to the point when you have to unlock the vehicle's doors mechanically (battery completely drained out, not even the key fob works anymore)
At first I have suspected issues related with vehicle's many ecu's and controllers, so I brought the vehicle right back at the dealership. In my country the VW dealers do not sell too many GC's, so their tech knowledge related with the camper part is limited. But they escalated the technical issue to the factory tech-support, so they made an online diagnosis together with the factory tech-support. The answer was that the discharge is related to an issue of the THULE step (the factory didn't knew the step was removed, so they asked the local technician to check if the step was damaged in any way)
To make the long story short, I have reinstalled the step and the discharge problem was gone. But still I would like to uninstall this garbage, as I don't see any benefit having it.
The VW dealer cannot "undo" the step, so they do not have a procedure to remove this as it was never installed from factory. Of course, it can be removed mechanically and just disconnect the plug, this is a 15' work, but this leads to the electrical issue, as apparently the ECU that controls the camper module will stay awake and keep trying to close the step.
This means a current consumption of about 0,12A that will go on until the battery is fully drained.
Any thoughts?
Hello Everybody,
Any thoughts?
Did you find a way to remove it completely without emptying batteries, i have the 4motion and is very bad for off-road
I removed the step from our 4motion 680 , becuase I knew it would get damaged. I have driven it off roads.
I was unaware of this battery discharge, but I do connect the van to 240v in winter and in summer it has solar panel on roof to keep battery’s fresh.
I guess that a dummy plug could be made to trick the computer into thinking step is present and closed.
Found this
Structure and function of the step
To retract and extend the step, the drive motor is energised, for a limited time, by the control unit for special
vehicles J608. At the same time, current monitoring takes place in the control unit for special vehicles J608.
If the step is blocked or fully retracted or extended, the current consumption increases and the activation of the
drive motor by the control unit for special vehicles J608 is terminated. For retraction and extension, the direction
of rotation of the drive motor is changed by reversing the polarity. In order to reliably detect that the step is fully
retracted, this is monitored by the control unit for special vehicles J608 with the aid of the button for the end
stop in the step. If retraction fails due to a blockage of the step when the engine is running, a warning tone is
sounded to alert the driver, and the function lighting in the button for the step flashes. The warning tone is
deactivated after approx. 15 seconds, the visual display continues to flash.
If the step can no longer be retracted, for example in the event of a power failure at the step, it is possible to
retract the step manually. To do this, remove the two securing clips, then unhook the two arms of the drive
mechanism underneath and fold them back. The step can then be pushed in and secured against slipping out
with the fixing clip.
