Error message on external powersupply to be disconnected
MCEv (Moxie)
MCEv (Moxie)
Holland
T6.1 Ocean 204 4 motion
I have on and off an error message stating that i should disconnect the external powersupply. Sometimes i get it a few times a day for just a moment, sometimes it keeps beeping for a few minutes, sometimes i dont have it for days. At one point , when it happened it was always on a left turn and steering to the right would stop it. Now , vibration from potholes or uneven roads would stop it or set it off.
Other error messages that sometimes come with it is that i need to check my left rear indicator and left break light. (Both on side of powersupply) None of these messages are correct.
The wardrobe internal light also keeps blinking in the evening, not sure whether related or not.
I am not close to a dealer atm and i am checking the connections to the leisure battery in the rear and they all seem firmly attached.
I am contemplating to pull the plug out of the inverter (see pic) and hooefully that will stop the external Power alarm. Anyone any idea about or experience with these warning messages
One of the two rear circuit breakers is connected to this, which might be easier. Certainly in the T6 there is a sense wire from this to the Camper Panel that is used to determine if the external power is connected.
Thanks, where would I find the circuitbreakers?
Sorry , i misread your post. I suppose you mean just flip it off . I seem only to have one circuitbreaker , so will test that.
H
Hans6049
H
D
motacyclist
motacyclist
R
23K
PaulBastowski
P
