Need an earth shunt kit
T5_Big_Blueberry
T5_Big_Blueberry
Hove, Brighton and Hove
T5 SE 140
So on a recent weekend trip our 2009 plate T5 SE started to show all the dreaded symptoms of a bad earth shunt connection - heater cutting out, lights + display flickering when starting the heater, fridge also cutting out.
I've learned about the repair and am willing to give it a go, but it doesn't seem that the kits are being sold any more. I've contacted campervanbits and the german caliground people, but neither have any in stock and they're not planning to get any more in.
So what to do? Thanks in advance!
You can get the parts from Halfords. Nothing that special.
See Post 5
Post in thread 'Shunt fix'
https://vwcaliforniaclub.com/threads/shunt-fix.22782/post-261445
There is a How to document in the Resources section of the Forum available to VIP members.
Thanks but that link just takes me to a generic brake pads page
On my phone the link is to a thread regarding the Earth Shunt repair and photos of parts required. Just checked working fine.
sorry, confused - the thread has a link to halfords that doesn't go anywhere for me, and post 5 has a link to the Caliground kit that is no longer available
Here we are these will need to be ordered from lll parts as tps and VW don"t list them anymore
first you will need an earth lead this is the size Hope this helps
one end is a12mm and ones end is 8mm overall length with ends is 62.5cmStrap
shunt kit
n90857502twin screw
n01100627nut
n0116555washer
3b0857799bolt
N010264washer
shunt kit
n90857502twin screw
n01100627nut
n0116555washer
3b0857799bolt
N010264washer
I just asked an electrician to make me up the cable and he queried the length - is it definitely 60cm?
I'm in the same boat - needing the bits to sort out the earth shunt.
Can I ask if you've sorted it, and how you got on with cable length and finding parts? Thanks.
Hi.
I'm not having any problems with the refrigerator or heating, but the % values and voltage on the control panel keep fluctuating wildly. I think it's a shunt problem.
I'm looking for confirmation. If anyone can tell me anything about this, thanks.
I'm writing from Italy and I always find lots of good answers here!
Tnk.
Davide
5K
camper-x
Andresz
7K
K64YUK
K
jts46
jts46
