Jammed rear bench seat/bed
Mikef63
Hi, my rear seat has jammed a couple of times so that only one side releases and it’s caused by the linkage arm coming out of its hole. There is a plastic clip that sits in the hole and the linkage arm goes through it as can be seen in the photo circled yellow, does anybody know what this clip is called or have a part number for it
Hi Mike , you haven't specified what van / model you have.
I suspect that will be a VW dealer part , you may be lucky and find something on line , (I have seen that type of angle fitting before , but it's not common) .
Update the post to help others
Exploded parts diagrams with part number and costs are available for entire California on line from LLL Parts .
Hi, my van is a 2013 5.1 which was converted using an ocean seat/bed. Don’t know what year van the seat came out off but I think the clip would be the same for most ocean seats up to 2013
The Merle
16K
Caledonian Camper
V
6K
T
