Right Angle 12v connector for rear cigarette socket
myvanrodney
UK
T6.1 Ocean 204
Anyone found anything (on amazon) that is nice and compact, so the plug doesn't stick out?
Any good?
Linkstyle 120W Cigarette Lighter Adapter, Car Charger with 3 Sockets, Dual USB-A Ports & LED Indicator for 12V/24V Car Devices​
Problem would be the sockets are fused at 15 amps. most plugs are rated at 15-20 amps hence protected by the circuit fuse.
In a house the sockets are supplied by a 32 amp circuit breaker yet the plugs are fused at 13 amps,what is the difference?
Also, I think you will find the 7.5 Amp rating is for 24v, so the rating is probably 15 Amp at 12volts
excellent thanks all
