Rear Fan Blower knocking / tapping issue
NoviceCaliOwner
NoviceCaliOwner
Christchurch
T5 SE 140
Hi all,
Rear fan blower issue : drivers side where the vent is and the catch / bolt for the lift up bed section.
Seems like a this tapping / knocking noise when I turn on the ignition to use the electrics - engine doesn’t need to be running. Sometimes it occurs for a short time and sometimes quite a long period.
Anyone have a YouTube video link on how to get into the vent to check it out or know what might be causing this issue?
Any ideas and possible ways to fix it would be appreciated.
Thanks in advance
Hi all,
Thanks in advance
Have a video but this forum doesn’t seem to allow videos on it
Upload to YouTube and then share the link in your post.
Thanks WelshGas you guru! I’m not a YouTube person generally so didn’t even think of that !
I have managed to locate the problem and it seems to be the little area where the white leaver rotates when the electrics are applied which causes the issue and the noise. Normally the noise lasts for a lot longer than in the video
Please see link below
Thanks in advance
Thanks in advance
Might try this to reset the flaps.
I know it is a different control panel but try the same buttons.
