Under seat door trim restricting drawer handle
  • Thread starter This_one_goes_to_eleven
  • Start date
T
Notts
T6.1 Ocean 204
Hi all - noticed last week that the black handle to pull out both my under seat drawers are now catching on the plastic directly above.
You can see the smaller drawer handle has been strained and is now not level.
The trim directly above seems out of loose to the right hand side as you look at it , I’ve had a fiddle but doesn’t seem to be anywhere obvious it snaps back into. If it was pushed back it wouldn’t be snagging the handle.
I am assuming everyone else’s trim is as far back on the right hand side as it is on the left?
24 Ocean 6.1
24 Ocean 6.1
Thanks in advance View attachment 135250View attachment 135251View attachment 135252View attachment 135253
Happened to mine, blamed it on the kids. Probably shouldn’t have done this but I just applied some force in the open position and straightened it up. It’s been fine since.
Thanks for reply.
The misaligned handle is really a side issue and I think it’s been caused by the trim above catching.
Did you have the trim like mine above?
Must admit I didn’t think I had the loose trim. Mine was just the wonky handle. I suspect the trim should just push back into place though once your handle is straight.
Yeah have tried, the handle doesn’t snag the trim as such. Can push it but it doesn’t seem to latch on anything.
