Can a fitted tracking device rain my battery?
  • Thread starter DessyParkerWigWam
  • Start date
DessyParkerWigWam
DessyParkerWigWam
Wigan
T6 Ocean 150 4Motion
When i leave my T6 Cali Ocean stationary for 5 days - my Main drive battery (not leisure) goes totally flat - It's a new battery and a new alternator - and charges fine everything else ok - I make sure everything is turned off and unplugged - had it into VW and they have said that it is the tracking device I had fitted from a very reputable tracking company (Fleetsmart), that is draining my battery. Ive heard mixed reports 1. It's the easy way out for VW to blame a third party device - and there is no way a tracker could place such a drain. 2. Others said that it is feasible. 3. Others have talked about a more lily cause being something called a 'battery monitor module'
I don't think I've any choice other than get the Tracker removed - and then see what happens - but really interested to know if other people have experienced similar problems with battery running flat in less than a week of standing idle - and if this has been linked to tracking devices?
PS I am technically and mechanically incompetent - so I'm not able to do anything other than very basic 'have a look' without proffessional help. : )
Technically, possible. A tracker has to draw something, else it will not be on. It all depends on the draw on your main battery from the tracker. Personally I would find it hard to believe that a tracker would draw that much to drain in 5 days.
Some have had an issue recently as the OTA updates stuck and that caused a constant drain and there is always the possibility that it is something else causing a current draw. The easiest way is with an amp meter and seeing what is happening to the battery at rest, with and without the tracker.
Trackers generally go into "standby" mode and then only use milliamps, so it is also possible yours is not going into standby for some reason. It is also possible the tracker has been wired wrong.
Have you got roof mounted solar by any chance? Or are you considering it?
That might just be an option. Get it reconnected to your leisure batteries. Twice the capacity and charging even on the darkest of days. You’ll also be able to find out whether VW were correct on the battery drain.
However it plays out, I hope you get a solution that works properly without loosing the tracker. There are other deterrents, steering lock, Ghost Immobiliser, moat and drawbridge, inflatable Trump dummy…
Roof solar in the main only does your leisures. While you can use for starter you tend to only get a 1A trickle and it’s quite variable when that kicks in. OPs issue is starter battery.
Indeed hence ‘get it changed to your leisure batteries’
Why don’t you talk to Fleetsmart?
Tell them that VW say it is their technology causing the problem.
I’m sure they would be very keen to check out the installation.
Ah, missed that part. Not sure they could hook it into the loom for that but they will know better than me. If it was causing a drain (which I doubt, if fitted correctly) I wouldn't want it on my leisures any more than the starter.
Thanks for the helpful response - by way of update - VW told me the tracker is drawing 0.14 and in their opinion this is what is making the battery run flat ... They would not remove the tracker for me or look beyond the tacker for other causes as they said it was third party devise ... I'm having it taken out on Wenesday - and then taking it back to garage for further investigation
Thanks - Ive not got solar - sounds like it is worth me investigating. The Tracker is being removed on Wednesday - so lets see what happens
You could ask them just to remove the fuse to the Tracker and then they can measure the current drain. You could also see if the battery goes flat over the same time with the fuse removed. If it still goes flat then the Tracker is not the issue. I leave my dashcam on most of the time and have never had a problem with it not starting and I would have thought that a dashcam had a similar drain if not more that a Tracker.
Just for an update - i had the tracker removed - and as expected that was not the issue draining my battery - the battery is now draining very fast - within 24 hrs. I'm booked back in at the garage so they can investigate more - from a bit of googling - I suspect it could be the battery monitoring system - Does this seem logical to others? But I don't really know - it's worrying that VW Van centre have not been able to identify this - they seemed incapable of looking beyond the Tracker - but now its not there it has removed their easy solution - hopefully they can work this out
Now that the tracker has been removed the fault now lies somewhere in the vehicle. I think sometimes it is easier to blame a 3rd party device for a fault.
Hopefully the van centre can now investigate the fault and get to the bottom of it. I know you said the battery was new was it coded to the vehicle. To me it seems like a battery have you had this tested.
By way of an update - they have now informed me i need a new battery - m current one is only 4 months old - i enquired about a fault on the Battery Monitoring System - then they suddenly told me i need a new Battery Monitoring System as well - feels like they are making it up as they go along. anyway - id no real choice other than to go along with this and see what happens - i pick the van back up later this week - Im taking it to Scotland for along weekend - so will get a good tet - fingers crossed because i'm travelling round Scandinavia in June - and i want reassurance that it will not keep dying on me ; )
Have you heard any noticeable sounds from underneath the left front seat (under the car). I have similar symptoms as yours, plus a buzzing and a fan-like noise. Today I was told by the mechanic shop that it is the aux heater. It might be a control unit issue.
