T4 Temperature warning message
Coxy_si
Apo11o14
T4 Hightop
Hi all, in cold weather (like below 10 degrees) I get a temperature warning coupled with loud beeps just after starting the engine. It disappears after about 2 mins. There’s no problem with the coolant level or normal running temperature I attached a pic (the lcd is in rather poor condition) I’m wonder if maybe it is the level sensor giving a false reading in cold weather. IMG_7035.jpeg
Hi all, in cold weather (like below 10 degrees) I get a temperature warning coupled with loud beeps just after starting the engine. It disappears after about 2 mins. There’s no problem with the coolant level or normal running temperature I attached a pic (the lcd is in rather poor condition) I’m wonder if maybe it is the level sensor giving a false reading in cold weather. View attachment 133749
Are you sure it’s not the Black Ice Warning that is triggered at 4 degrees or below?
I don’t think so. That ice warning works any time I’m driving. This only happens after cold engine start and goes away as the engine warms up.
