Sorry Now Sold Rainbow insulated T6.1 pop top cover plus many other accessories
GGaa
GGaa
South West
T6.1 Ocean 150
Rainbow Insulating T6.1 pop top full wrap around cover for sale. Hardly used and in perfect condition but have sold Cali so no longer needed. Cost new is £208. Happy to sell for £125.
Be great if can pick up Bath area or possibly can post.
Have huge amount of Cali accessories for sale such as Thetford Porta Potty x 2 (both small and normal size), black front screen insulated cover (wrap around wing mirrors as well) perfect condition, Vango Palm low driveway awning, wind out awning sides, Wild Earth sun/rain canopy (for passenger side of vehicle), extremely useful pull out under rear passenger bench seat long thin drawer, over sink /cooker shelf, portable solar system including Victron inverter by Bimble Solar (just done three months in Europe all off grid using the portable solar), front floor cover etc. Will advertise items separately in due course but if you have just bought a Cali we can save you a lot of time and effort! Can send photos of all other accessories.
Hi there, I will take the pop top cover if you are ok to post?
Can you elaborate on the solar system. I don’t mean like Stephen Hawking rather which set up is it please.
This was the original order:
4 x 6mm² cable end lug, 8mm hole, heavy duty copper tube terminal
3 x Anderson 50A Black Connector with 6mm terminals - quick cable connect & disconnect
1 x 12V 120W portable folding solar panel with SunPower Cells - lightweight, High Performance cells, perfect for Hymer , T6 , Caravans etc
1 x 10A Victron MPPT SmartSolar 75-10 - 75VOC PV Charge Controller
10 x 6mm Solar Cable - per meter
All you have to do is connect to battery under seat and leave victron box under seat - can talk you through, it is extremely simple. You can then connect the panel to the battery via clip connector and put wire through minimal gap in window above sink. Can then move the screen anywhere outside to face sun. We have even come back in afternoon and people have move it to continue facing the sun for us. When not in use the screen folds up and takes up almost zero space in drawer under bench. Can also put in front window if you are parked in town and worried the screen might be stolen. Never had a problem and used for 4 years. It is much nicer than hooking up since able charge for what you need. It also links to you phone so you can see what is happening real time. Hope that helps.
Is £40 ok? Can you pick up or does it need posting? If posting then plus cost to post.
I’m in Bristol so pick up is fine. I’ll check with the wife to see if she’s happy with it first. If we can do £35 that might seal the deal…
Prefer to stick to £40 if that's ok. Only used it a couple of times so in good condition.
Ok, let me know when you’re available and where to collect from. I’m going away in the van next Friday so wouldn’t mind picking it up for then.
I around most of the time, what time of days works for you?
Hi, could you send me more details of the black front screen cover please? Does it cover the side windows and do you have any photos? Thanks
This is a link to the product.
So yes it does cover the side windows.
Hi, if it’s still available I will take the screen cover. Could it be posted as I am in North West and cannot get down to Bath easily. Thanks
Splithens
DAVIESA1000
mintyman
mintyman
YorkshireWander14
YorkshireWander14
YorkshireWander14
