Moggymog
That list is growing!!You don't realise how light the tinting is at first... another on the list of "might do" for me
Yes sure - I’ll take one tomorrow for you as bit late now and only just seen thisDo you have a pic of them fitted? Please!
Spot on - I have those Yeti’s they are fab and a hot tea will last 2 hours (if not longer) no problemGave in to temptation at yesterday’s show. Ordered a Rainbow windscreen cover too.
What level of tinting did you have fitted, looks good from the photos.@AdamsFamily msybe not the best pics but definitely an improvement in my opinion, going for a rear spoiler fit tomor & front lowering springs next week
@Van Diesel VW one down from total black out limo tint, the guy reckoned it would’ve been too darkWhat level of tinting did you have fitted, looks good from the photos.
Fitted a ‘stealth’ rear spoiler, painted gloss black
Massive change on visibility when cornering. You do wonder why halogens are the standard fit on VWs. We will be going this way for sure! EDIT - now on order, ready for a trip over the Channel.Sorry I forgot to report back. Yeah very easy to do and no errors on the dash
I cable tied the driver units to stop any annoying rattles
New one on the drivers side to show the difference
Can't beat a Yeti Mug!!Gave in to temptation at yesterday’s show. Ordered a Rainbow windscreen cover too.
I’ve just fitted these Autobeam bulbs - they look good. One thing I’m nervous of is, whereas the OEM bulbs are a tight / positive fit when you quarter turn them, the tab fitting on the Autobeam bulb turn (so you can orientate the led) so I feel they’re “just” gripping. Not sure if they’ll survive a speed bump / pothole!Campervan Time installed them (granted not on a T6.1 but.....)
Yes pretty much. Same bulbs. The left hand one was a bit trickier to get at the plug - more stuff in the way. I used tie wraps to support the weight of the electronics block - attached to other local wiring.Was the installation as simple as on the MANs video above? Also an H11?
I found that gripping the "bulb housing" when twisting and not just the central LED part I was able to mount it tightly.Yes pretty much. Same bulbs. The left hand one was a bit trickier to get at the plug - more stuff in the way. I used tie wraps to support the weight of the electronics block - attached to other local wiring.
I’m going to have another look at the fitting of the new leds though - just not happy they’re properly clicked in (per Wills video ).
Excellent....looks much betterJust had another go. This time I put a ‘tiny’ drop of lube behind each of the 3 little flanges and then pushed the bulb extra hard into the housing and gave it a quick clockwise twist. It’s now fully home.
