Califan61
Hi all,
I have been experimenting while the Cali is plugged into the mains and the leisure batteries are fully charged when does the starter battery start getting charged as I have read this in the manual.
I have left items plugged in to accelerate the drain and down to around 11.9v the Cali does not request the starter is charged and starts up as normal. Today I checked again, it's now down at 11.4v, it's saying low starter voltage and requesting charging by starting the engine. At no point has any charge gone into the battery so either T6.1 don't have this function or I have a fault. I did raise this the last time I went to the dealer and they said the system is working correctly. Is anyone able to confirm either way whether the mains does or doesn't charge the starter battery please? I'm not bothered if it now doesn't charge the starter battery I can then find a way to keep it charged.
I have added a graph from the starter battery monitor which shows a passege of use, then a steady decline but no top up. The van was then plugged in and within 24hrs the leisure batteries where fully charged. The increased discharge in the middle was me sitting in the van doing some work. It remains plugged in currently.
