Truman
Like a complete jackass I've realized that I didn't empty the water tanks when we left Llanberis wales on the 4th Jan. I was midst cleaning Dave down today when it dawned on me, and the tanks are frozen solid. With the valves frozen I had to come up with a solution to thaw out the fresh water tank, as I knew that one was almost full opposed to the waste being very low.
If this has happened to you then can I make a suggestion that will allow you to thaw out and drain the fresh water tank.
Remove your gas bottle, remembering that for some odd reason it's a left hand thread, so righty tighty, lefty loosey doesn't apply for this connector.
Fill a 5L plastic bottle, like the one you get your screen wash in, with VERY HOT water pop it into the void and screw the tank lid back on.
Change the water after a few hours, but by this time your tap should allow you to open the valve to start the draining process.
My tank drained after 4hrs, hopefully no damage.
I could have cried earlier.
