GC600 jump start advice please
Z
zil4519038green
Scotland
Grand California 600
Hi there, my first post on here, but have been reading these forums avidly for lots of tips, an amazing resource.
Our GC600 is currently completely flat, having not been started in a few weeks. Not a single light on the dash, and had to use the key manually to get into it. I have borrowed a Noco Boost XL 12v 1500A jump starter rated for "up to 4.5l diesel" Is this ok to use or too big for the GC? (i'm not sure if the bigger capacity is problematic, or merely more than I need).
The leisure battery was replaced just last month (December 2024). I know the advice is to throw the red isolation switch for the leisure battery, but since getting into the habit of turning off the red switch this is the second time that the starter battery has ended up completely flat. When we didn't turn off the red switch there was never an issue with the starter battery being flat. Are these connected? We have the factory fitted solar panel. We also live in a flat and don't have any facility to plug-in / charge at home. Any tips to stop this happening for a third time? I'm minded to ignore the advice and keep the habitation electrics switched on if this is connected to the solar and sharing something useful with the starter battery?
1. Lithium boost for the jump start fine.
2. Red switch reduces back ground power draw on leisure but does not zero it. The leisure battery will still slowly discharge,, albeit at a slower rate with the red switch off. Factory solar this time of year (January) will likely not keep things going either way especially if the GC is facing north.
3. Solar unaffected by red switch position and does not maintain starter which will also flatten if left unattended for long periods. If you can leave the GC on EHU over winter when not in use that will keep both batteries in good condition and uses around 0.6kWhr per day. At the very least over winter plug into EHU every couple of weeks.
Ive attached a doc that gives a bit more detail.
  • MM001- Battery Banter Issue 02.pdf
Thanks GordonH, this is really helpful. The document you've posted is a brilliant resource, thanks so much.
So just to confirm re "1. Lithium boost for the jump start fine." This means that my propsed 12v 1500A jump starter device which I've borrowed should be ok to use and won't be overloading it? Thanks again.
Yes, it will work fine and No, it wont overload anything. The GC will take what it needs from the lithium boost battery to start the engine so it will be fine to use. The ‘up to 4.5l’ means thats the maximum engine size it will be able to jump start. It will work fine on smaller engines.
Brilliant, thanks GordonH!
A big "BRAVO" Gordon for this extremly clear and usefull doc.
Many thanks for this anchor, ie buoy for me, in the stormy sea of GC batteries :)
