Power steering terror
pchmlk
pchmlk
Surrey
T5 SE 140
We came down to Portsmouth last night for some early morning fishing on the boat today.
When we got off the main roads, there was a strange noise at lower speeds. I initially thought it was gearbox noise but then noted the whine was worse manoeuvring and checked the power steering reservoir - almost empty. Under the drivers side suspension, lots of fluid.
I can’t see where it’s coming from and am having to leave the van here and get collected. There’s a general motor mechanic 100yds away I’m going to call tomorrow. Any thoughts on what it might be and likely £££?
Hopefully it’s that then. Or a cracked pipe.
The pump is visible from underneath, driver side , just inside the engine bay , low down (approximately middle of the wheel arch ) , if it is leaking it will be obvious, (given the loss of fluid) if not look to the steering rack gator.
Put the steering lock to lock, the noise will be a high pitched whine !
I’m not with the van anymore, I needed to get home. I’m at the mercy of a local mechanics.
Thanks for the advice, I can use that when I speak to them.
Fortunately local mechs won't use VWs Labour rates !
All resolved now. It was a fracture in the metal end of the high pressure hose by all accounts. Luckily no pump damage but still quite a pricey surprise.
