Webbah_in_Switzerland
That hotspot should be ok, but I previously had a Netgear Nighthawk as it also has an optional external antenna that can be mounted on a window via suction cups. That dramatically improved the signal in some spotty areas. Something to consider if you are truly a swamper and out in the boondocks. I really would advised to have a look at FTS Hennig (it's in German but these guys really know their stuff)Apologies for the thread hijack. Back on topic.
I will eventually fit a Stsrlink to the wagon, so I am following this thread with interest; especially WRT how to skin the cat of delivering it power. @Webbah_in_Switzerland as ever has the primo example, just not sure my less frequent use case justifies an elaborate setup.
While I mull things over, I usually buy a placeholder to keep things ticking over.
So, I’m mulling a 5G router - as with everything, a multitude of options and price points.This was recommended by some people who had tried a few options.
https://www.amazon.co.uk/dp/B0C37FRYV5?tag=unique09f-21 (I know everyone has their preferred brand etc.)
Are there certain specs (carrier/SIM compatibility aside), you tech heads would recommend as most important for speed & connectivity?
I liked the notion of potentially wiring this to the adapter I have with USB-C output in the Victron load to charge it in summer. Trying to get my head around how 10,000 mAh translates to surfing time.
Use case - not work. Just a hotspot for 2 devices, light useage at night to maybe play an audiobook for the gremlin and for me to keep up on the swamper forum on here.
from the hit it took…
