DGM
Hi, have looked through the pdfs but can't spot the location of the fuse for the windscreen washer pump, any help appreciated.
I have a 2011 model.
Did you solve this?I had the same issue and have changed the blown 7.5 amp fuse...... next fuse blew immediately and nothing else happened. has anyone had the same issue, is it the pump at fault or is there a switch in the windscreen wiper control arm? still getting absolutely nothing, no noise, no water but wipers moving.
2 possibilities.Did you solve this?
I just had the same, replacement fuse blew straight away, so wondering what to do next…?
Thanks for any advice
Hi, it was the pump that had failed and needed replacing.Did you solve this?
