Z
zipf
Hi, parking heater question... This is on a '24 Beach Camper. We used the parking heater overnight recently (not on EHU) and it was more of a disturbance than I was expecting, so wanted to check whether this seems normal:
Is this just how it normally works, or does it sound like something's not right? Thanks!
- On first turning it on (continuous mode, level 3 or 4), it goes through some normal startup noises (ticking, whirring etc.), then the fan comes on and soon blasts warm air, it's pretty loud (but just fan noise, no squeaks or anything odd).
- After a while (5-10 min maybe) the fan slows, still putting out warm air.
- Then after another 5-10 min it seems to turn off (although testing this afternoon, I noticed close up that it was still running very quietly with a little cold air output, at least for some time).
- Some time later, presumably when the temperature drops sufficiently, it starts again at 1, high fan speed etc. (I'm pretty sure with the startup noises again, although might need to confirm that when not half-asleep).
! (I was determined to see just when it was going to switch down, but ultimately it beat me!). I changed to setting 5, it dropped down to low heat output, so I opened a door and window to see if I could keep it there. Maybe wasn't quick enough because 4 min later it turned off completely (well, went to the minimal cold air output). At this point, with a headache and slightly less full diesel tank I quit. On the plus side, I did get some drying done.
