Almost bought a california
I’ve been looking for a way to block one or both pop-top vents when the temperature drops a bit or the wind gets up. I was looking for a method that would be invisible when not in use and could be left in place when raising and lowering the roof.
Velcro would have been the easy option but I thought the Velcro would be unsightly and wasn’t sure how well it would last so I opted for some darning needle inserts and fabric covers with magnet inserts – I used 2mm thick nickel plated steel needles (not the stainless steel needles which would non-magnetic) and 10mm*20mm*2mm magnets.
The end needles are easily bent to match the 40mm radius of the piping surrounding the vets
I used 4 needles per side and they are easily inserted and worked around the piping surrounding the vent without making a hole or damaging the piping material and once fitted are almost invisible
The 4 magnets have just been sown into an 80mm*200mm scrap of quilted material for now for proof of concept but properly road tested now and I can confirm a good nights sleep without all of the cold drafts. This arrangement works very well and stays in place quite happily when the roof is lowered and raised again. Neater Mk 2 covers now on the job list
