ST111
I have a 2015 T5 California I have had since new and now with 135k miles so I know the van well.
Recent trip to Portugal it developed a "loose" loud knocking noise high up above the cooker/underside of the roof when going over rough ground. Had it checked to see if any issue with suspension which may be resonating but all good. There is wear on the near side underside of the roof caused by contact with the main scissor raising and lowering scisor struts.
I have tried shaking the roof but nothing obviously loose and it still powers up and down. I did note that when partially raised the side with the wear the actuator piston is extended about 1 cm less than the "good" side.
Has anyone experienced this problem and any hints at what to look for.
