vw multivan t6 rns410 factory mix bundle
D
dex92
Balingen
T5.1 se 180
Hello. I have a problem with the factory microphone beam, we swapped the radio for android and would like to connect the microphone with the android radio, and my question is where to look for the microphone ? In the ceiling? Is the 1/7 pins in the blue quadlock cube from the microphone ?
Cannot help with the cabling, but the mic (if you mean the mic that picks driver audio and sends it to the rear area), that is just above the driver sunshade.
Najlepiej będzie, jeśli dokładnie sprawdzę przewody wychodzące z mikrofonu i wchodzące do kostki radia.
It's best if I check exactly the wires coming out of the microphone and into the cube of the radio.
To use the microphone in an aftermarket unit you will need to have a canbus converter, most aftermarket head units come with a new microphone that is used instead
Are you talking about csnbus which is included in the set to the radio ??
On my T6, when I replaced the oem head unit with an aftermarket one, in order to keep the oem functionality such as steering wheel controls, microphone, front and rear sensors, an additional unit was purchased which interfaced the replacement head unit to the vehicle Canbus system to send and receive the necessary data packets in the way that both the head unit and the vehicle understood.
This way I could reuse the internal microphone and see and hear the reversing sensor information on the screen, it also allowed for other info not originally available such as heater controls and it allowed the audio and navigation information to be replicated in the multi function display in the dashboard.
