Installing lithiums for Leisure batteries on 2005 California
D
Doug Curran
Victoria, Canada
T5 SE 174
Has anyone information whether it is possible to install Lithium batteries in place of AGMs for the leisure positions on a Cali?
I’ve just done it in my T6. You will need a DC-DC charger to replace the split charge relay. On my T6 the AGM profile of the EHU charger is fine with most LiFePO4 batteries. The shunt for the multi-function display still works although the Li batteries will have different voltage so you will lose a bit of accuracy but it’s still a useable guide. Also on EHU the trickle charge to starter battery still functions.
I installed 2 Xplorer Polar Max 100ah batteries which has effectively over doubled my useable capacity at less than half the weight. The Polar Max will charge and discharge down to -20°c. which might be important if you’re in Canada! Non heated Li batteries will only safely charge down to 0°c. I had a bit of a juggle to get the battery to fit in the rear, I’d recommend looking at the Titan batteries which are more expensive, slightly higher spec but have a 100ah model that is exactly the same size as the existing AGM batteries making install much easier. You will likely have different options available to you locally. I used a Victron 50a smart DC-DC charger which is both small enough to fit under the front seat with the battery and sheds heat very efficiently.
Budget wise (including additional cabling) batteries and charger it’s between £1-1,500 in UK, I’m guessing similar in USD. It’s doable if you are a competent at DIY with a good understanding of auto electrics if not you will probably need to budget for 6-8 hours labour for install by a competent auto electrician. The trickiest bit is wiring the DC-DC charger to the battery/alternator.
Hope that helps.
Budget wise (including additional cabling) batteries and charger it’s between £1-1,500 in UK, I’m guessing similar in USD. It’s doable if you are a competent at DIY with a good understanding of auto electrics if not you will probably need to budget for 6-8 hours labour for install by a competent auto electrician. The trickiest bit is wiring the DC-DC charger to the alternator.
Hope that helps.
How did you connect the DC-DC charger and still have trickle charge to the starter battery on EHU?
A circuit diagram would be very useful to any of us that want to do the same.
I didn’t do the install alone I enlisted the help of an expert! I tightened some bolts, made the tea and did a lot of swearing manoeuvring the new battery in the rear cabinet - VW basically left no wriggle room with the hatch even though there is 20mm or more length and a bit more height space for the battery in the cabinet.
Essentially we utilised all the existing cabling and connections from the EHU charger and connecting the two batteries to retain all the original functionality I listed above. This also greatly simplified the install. The only new cabling we ran was 25mm2 (the existing 16mm isn’t big enough for the 50a DC-DC) along the existing split charge relay cable route. This then runs under the scuttle panel behind the wiper linkage (had to remove the wipers and the plastic scuttle tray) and into the engine bay to the starter battery.
Thanks for the reply, didn't realize you could get trickle charging of the starter battery with a DC-DC charger. What make of DC-DC charged did you use? Was it the Victron 50 amp Orion XS?
Hi, It’s the EHU charger that does the trickle charge not the DC-DC. By not changing out the factory fit EHU charger (which works OK with LiFePO4 batteries) and leaving the wiring as is you retain all the original features in the Cali set up.
I used a Victron 50a smart charger. If you have solar you can use an MPPT to trickle charge the starter battery when not on hook up if that’s an important feature for you.
Do you really need the extra capacity ?
Messing about with lithium batteries and installing in a van that has worked happily for 20 years on lead-acid technology is not without risk.
Even industrial giants with billions of R&D budgets can get it wrong.
Yes, fire is something that worries me too. Do insurance need to know you've fitted lithium batteries?
If they want to know if you've lowered it 1/2 an inch or fitted a spoiler surely fitting different batteries would be a big question??
D
Emil Silenhag
Emil Silenhag
No_heroes
Neilos
Neilos
K
GollyOlly
GollyOlly
