Anyone know if you can?
Meoncoast
Meoncoast
A Beach at a Bay,
Moorgreen
I don't know what this is, but can you tell me where you can get these? Pop on straps for seat tidies.
Is it one of these ?
You could try contacting Brandrup direct to see if they have them as a spare.
If not have you thought about making some.
Just need to have a popper press from amazon and some material to press onto.
Do you not/could you not just slide the headrest through the holes?
Designed to be held in place by just the headrest. Remove headrest and insert through holes and fit beck on seat.
I thought in addition to the head rest fixing, the pop on bits went round the armrests to keep the middle of the pockets tight against the backrest of the seat.
Yep.
I guess you could find some small enough covered wire, gardening wire maybe - and feed that through the popper base, make a loop and then tighten together to get the tension :)
Cheaper than getting all the other stuff.
Was just a thought ! :)
The two hooks on the bottom clip to the bottom of the seat to keep it taught. The armrest loops are not needed; Possibly intended for a different seat type.
