Perfectos
be careful that the board doesn’t stretch the map pocket (it will bag)
Did you drill holes into the board and adapt the mounting prongs or are they screwed on?
OT: I assume you have/had an Aprilia Tuono. Great bikes. I had a Gen 1 Tuono Factory for over 10 years.Did you drill holes into the board and adapt the mounting prongs or are they screwed on?
Purchased some oem table prongs and cut them down and drilled into the hardwood board about 2" long and rubber glued as well so there going nowhere.Did you drill holes into the board and adapt the mounting prongs or are they screwed on?
Just trying for size it's back in it's normal place now out the way slid down the left hand side of the 3 seater along with the stove's normal place.be careful that the board doesn’t stretch the map pocket (it will bag)
Yes, though sold a couple of years ago, arthritic knee stopped play.OT: I assume you have/had an Aprilia Tuono. Great bikes. I had a Gen 1 Tuono Factory for over 10 years.
Can you tell me where you got the prongs from - many thanksWish I'd seen this earlier as I was in IKEA the other day. Already have a couple of prongs I bought years ago as spares. Like yourself I want a table so that it's easier for tea/coffee duties.
Have a look at this threadCan you tell me where you got the prongs from - many thanks
www.gruenthal-mobilcamping.de
Great ideaI have just made a "Galley Box" slightly inspired by the dinghy cruising fraternity. We use our Beach as our only vehicle so I didn't want to clutter it up too much. Although we normally cook outside, we brew up our breakfast coffee inside, and may occasionally cook inside in the winter. The idea of the box was that it would hold everything needed to make breakfast, and no more. I didn't want it to become too big. The box would help stop splashes of bacon fat if cooking inside, and act as a windshield when cooking outside. It was made of off cuts of plywood.
A couple of years ago I knocked up a small table which normally remains set up when we are camping. I thought the box should fit on the little table but it transpired it was better sitting alongside it. I have posted a little video on YouTube to show it in action: You can watch it here
I've attached a few pictures below but there are more details on my blog.
I hope you like it!
Well, the gas cooking slide out part is about €2700. The other panel is around €2000. And then you'll need a lot of other stuff too, so I would try something else.I'd be interested to see what the cost would be, eye watering no doubt.
It would be a useful addition to our beach, especially on day trips
Get a boot mounted slidepod with two burners, sink, onboard waste water tank, mounts and demounts in 30 minutes, should be cheaper than the prices above by about halfWell, the gas cooking slide out part is about €2700. The other panel is around €2000. And then you'll need a lot of other stuff too, so I would try something else.
There are a lot of aftermarket solutions with sink and gas burner.
