Victron Smart Shunt - where to install?
Big Ted
Big Ted
Bristol
T5 SE 174
I’ve searched, but not sure I’ve found any definitive answer.
2008 Cali SE. 2 leisure batteries.
I’ve managed to come across a Victron Cerbo unit, which is now installed. This connects to my Victron MPPT solar controller & onward to my VictronBattery sense device to.
With this new Cerbo unit I can access the data remotely when the Cali is in range of a known Wi-Fi network. (I don’t need this, but it’s nice to have)
I’m now thinking I’d like to install the Victron smartshunt, again I don’t need it, I’d just like to complete the family!! But the question is where/how?
Has anyone done this on an SE?
From what I see the newer Cali’s may have 2 existing VW shunts, I believe I only have one on the rear battery.
Victron documentation suggests the shunt should be connected directly to the ‘-‘ battery on one side of the shunt and all the connections which were on the battery should be connected to the other side of the shunt.
Other posts on this forum suggest putting additional (non Victron) shunt in series with the existing one.
Has anyone installed one and if so, how?
(I’ll post a review of the Cerbo unit later, as it’s also paired up to some Bluetooth temperature sensors and soon to a replacement fresh water tank sensor)
Hi, did you get anywhere with this as I’m considering installing a SmartShunt too.
I would be interested as well. I have a mppt smart solar controller and 200w solar panel so this would help with the battery % instead of voltage.
My understanding is the MPPT is what adds complexity to installing a smart shunt if you have a dual battery set up ie an Ocean/Coast. If you have a single battery ie a Beach then I think it’s pretty straightforward. I have an Ocean with a Victron MPPT connected to the rear battery and I can’t find a definitive answer as to if the SmartShunt will work ie record the solar and split charge (or in my case DC-DC charger). inputs to both batteries
I installed a smartshunt and connected this to the Cerbo unit.
I was getting mixed results. I tried to have the shunt in series and in parallel with the existing one, but regardless of what I tried it never really reported what I expected on the display of the Cerbo.
I then found the Cerbo wouldn’t reliability reconnect to my home WiFi after being away from home, so decided it wasn’t for me.
I returned all the items and now just have the MPPT which in reality is more than enough for my needs.
Good luck if you choose to get one, it would be interesting to see the results.
The Victron shunt can monitor a second battery - see attached. You can download the relevant manual from the Victron website.
My understanding is this is really so you can monitor the starter battery as well as the leisure battery(s)? A nice to have feature for sure but I’m still not sure I can make it work for me with MPPT connected to the rear battery.
Have you left the Victron battery sensors on? If so do they measure current as well as battery temp?
I think for the shunt to measure consumption (Amps) you have to treat the 2 leisure batteries as a single unit or 'battery bank'. Part of shunt setup on the app is to input your battery capacity so say each leisure battery is 80Ah you would enter 160Ah.
How in the Ocean are the 2 leisure batteries connected? (I have installed a shunt but in my Beach with only 1 leisure battery). Specifically are the -ve terminals connected via a dedicated twin cable between the 2 batteries (option a) or does it use the vehicle body as a common earth (option b). If (b) then the likely difficulty is that you cant ensure all the loads and chargers all go through the shunt to the 'battery bank' -ve terminal.
If its (a) then you should be ok to install the shunt under the passenger seat, but ensure that the -ve side of the solar charge (MPPT) connection into your battery bank is also via the shunt. i.e it may currently be a direct connection to the -ve post of the rear leisure battery. If its not via the shunt then it wont know when power is flowing in via the solar.
Can the original VW shunt in a California T5 be simply replaced by a Victron Smart Shunt?
And where is the VW shunt installed, under the front seat?
Nobody replaced the VW shunt by a Victron Smart Shunt?
Am I really the first one with this idea?
Yes.
The split charge relay is next to the front leisure battery, under the drivers seat LHD.
There is a How to article in the Resources section for VIP members. It is for a T6 but it is the same for a T5.
Yes.
I understood that the original VW shunt is located below the refrigirator.
What do I need to with the split charge relay to replace the shunt for a Victron Smart Shunt?
My mistake. I thought you were referring to a Victron DC-DC charger to replace the split charge relay.
I've not heard of anyone replacing the VW system.
Either replacing or wiring in parallel might seriously disrupt the Control Panel functions.
That was indeed my fear, that the Victron Smart Shunt would not match well with the control panel.
But since we recently had two 110Ah LiFePO4 batteries installed, the control panel is already giving an incorrect battery SOC.
In what way?
I have t6.1 ocean, I put 2x 314ah lithium batt to replace the original 2x 75ah AGM.
The 2 batteries' positive are connected directly.
The 2 batteries' negative are connected via their own vw original battery monitor module and onto chassis metal each.
So in that case you can not use a single Victron shunt to monitor both battery's combined current unless you use a thick like 4 awg wire parallel connect 2 batteries' negative then you can go into a single shunt.
Otherwise, I just removed the 2x original vw factory battery monitor module as they are useless now and replace them with 2x victron smart shunt.
Why remove the 2x original vw factory battery monitor module?
Because now I have 628ah instead of 150ah of leisure, without changing the central control panel's registered battery capacity, it will charge to full no problem, but when it discharges it will go down very quickly as it's only registering 150ah of capacity rather than 628. So now I just use phone to check the soc and it's accurate
In a T5 the two batteries are connected to a single shunt N162 in the electrical layout
Fogstar drift 314ah battery ?
I assume you have fitted the 314ah batteries under the front seats? And if so, replaced the split charge relay with a DC-DC charger? If so where did you manage to fit it? One final question if you don’t mind, did you replace the VW AC charger too? I hardly ever use the EHU when I upgraded to Li but when I do I’ve found the gel profile of the VW charger does the job adequately and still retain the trickle charge function for the starter battery.
Yes Fogstar 314ah cell a grade.
They are very very good, so far my active balance not been actived yet very unified cells.
Yes I use 314 cells to build the 314 12v pack, they are same size as the original 75ah AGM. To fit inside front seats you need to lay them down. Also I put under driver seat (RHD, uk model) as there are more space.
Yes you have to change to victron DC-DC charger I use the 50A one, fully charging 628ah takes 12 hours of drive. But I have 300W solar as well, even I have the fridge working 24h I don't need AC plugin to charge my battery. Actually I have now stoped charging from alternater as with only the solar my battery is always at 90-100%. With this setup I don't need any ac or alternater charging only solar is enough.
Yes i have removed the original agm profile charger but haven't installed a new li profile charger yet
