Ocean Wanderer
+++ I HAVE REALISED, WHILST ON TOUR THIS LAST WEEK AND A HALF, THAT YOU CAN GET ACCESS TO THE BACK SIDE OF THE 240V SOCKET MODULE FAR MORE EASILY THAN I PREVIOUSLY DESCRIBED SIMPLY BY SPINNING THE DRIVER'S SEAT THE FULL 180 deg, SLIDING IT TO THE APPROPRIATE EXTREME, AND TILTING THE BACKREST - SEE PHOTO BELOW. I HOPE THIS HELPS ANYONE WHO STILL HAS THE INCLINATION TO 'FIX' THE ORIGINAL DESIGN ISSUE. THANKS.
Big thanks for your advice on modifying the 240v socket. Not sure that I could have done it without your detailed instructions because I just couldn't work out what held the socket in place until I read your post showing how to release the retaining clips. A couple of things that I found made it easier: 1. Rotated the seat to gain more access as per your suggestion. 2.Moved the inverter out of the way by undoing the 2 retaining Torx screws. 3. Once I had removed the plug surround, to save dismantling the spring loaded flap I simply used masking tape to hold it back while I trimmed back the raised edge. 4. To avoid damage to the surround I masked off around the raised edge before I started trimming with a sharp blade. The whole job took less than half an hour - thanks to your input. Now I don't have to prop my MacBook charger up with a kitchen sponge to keep it from falling out of the plug socket - plus the spring loaded flap is now in a much more sensible orientation!!Followed your instructions this evening - worked perfectly thanks. Hardest bit was getting the bloody spring for the cover back in the right place. Flange (love that word) removed, and plugs fit nuch better. Many thanks JR.
