Removing sliding table
nigpdreadingfc
nigpdreadingfc
Cheshire
T6.1 Ocean 199 4Motion
Hi.
I want to work on the underneath of the sliding table, to replace the worn out catch that locates the bottom of the leg when folded up.
Is there a knack to getting the table out of the runner, please? TIA
Hi it's very easy to remove the table.
there are pins that go through and form the internal of the hinge.
Use a small screwdriver and gently prise out the plastic pins and the table comes off the runner.
Regards Neil.
Regards Neil.
Before I set to, is this the pin to remove? Can it be prised out from below? Thanks
