T
turnitdown
There are a bunch of threads about the Joolca hot tap system, but I haven't found anything about the hot tub. Has anyone seen one of these in action, or heard anything (positive or negative) about it?
It's basically an inflatable hot tub made of that same rugged material stand-up paddle boards, inflatable kayaks, etc are made of. You use the Joolca Hottap to fill it and recirculate the water.It comes with a pump so you can draw water from a lake or stream, you don't need all that water on-board.
My use case would be wild camping in Scotland, specifically a hot tub under the stars after a hard day on the Munros. If would be awesome if it all works as advertised. I've found some YouTube reviews but they are very unsophisticated, e.g., no info about the temperature of the water going into the unit, for example, which is important.
If I got the hot tub, I'd get an underslung lpg tank (easy to fill here in Scotland). If I just get the shower, I'd use the 907s. So that would be an extra expense. But if I were sitting under the stars in Glen Affric in a hot tub in winter, I'd never think about the money.
The main things that I wonder about:
- how good it is at drawing water from lakes/streams in terms of hose length and rise
- how good it is at getting water hot when the water coming in is, say, 4C.
- whether there is a heating unit similar that works with salt water. There's a lot of ocean coast in Scotland and it would be brilliant to be able to use it instead of freshwater (maybe with a quick freshwater rinse afterward if need be)
