Flyscreens Mesh Side Sliding Door
Little owl1963
Little owl1963
Walsall West Midlands
T6.1 Ocean 150
Home Bargains £4 , Black slightly shorter on width by around 200 mm , solution is buy 2 of them and add on the extra 200mm attach all joints with stapler .
if required buy a roll of magnetic tape , and affix with clear CT1 silicone , cannot recommend this CT1 enough has multitude of uses .Sets within 20 mins , 24 hrs full strength once set will not come apart .
For the top fixing fold over top to make a hollow of around 2 inch's then Staple , of which a plastic piece of plumbing overflow pipe can be fed through , then wedged / held between top slider hinge an recess adjacent to front door .
Plus point is with the home bargains patio door screens is , no zips to open and close !!!!!
They work on magnets on either side of Each mesh coming together , works efficiently and easily .
Very surprised custom built makers have not used this simple effective idea , lot better indeed than zips any day .
Did try the Ginger Tech one off Amazon for £20 out curiosity , very disappointing !!!!!!!
Appeared top quality thick mesh that's about it !!!!!!
Failed on magnets !!
Failed on double sided zip as stated , actually is single sided zip .
Failed on full length zip , impossible to get out of it with safety hazard of tripping or falling over !!!
Think i stick too 2 x home bargains ones myself and converting them , for £4 A piece you cannot go wrong .
Just looked at just campers £24.99 side door flyscreen has any one tried this one ??.
:DHome Bargains £4 , Black slightly shorter on width by around 200 mm , solution is buy 2 of them and add on the extra 200mm attach all joints with stapler .
This is a mental post
my home made one is post no. 10 on this thread.
Agree.
Dead easy to make a bespoke midge net for about £30.
Note: mosquito / fly net is inferior to midge net in many remote places.
