kurienp
Yes, it seems it is. Not to worry. Two days and it is still working so you will not have any issues on the 6.1Is this any better on the T6.1? Forgive my ignorance.
Sent from my Pixel 9 Pro XL using Tapatalk
Over the awning rail and then in through the drivers door. Close the drivers door on the cable and it is fine. Plug into the 240 v inverter on the passenger B pillar.@kurienp how do you route the cable from the tailgate into the van?
Try it at a south facing window. The north that they mention is relative to the equator. If you are far up north such as scotland, you may have to point the dish towards the south, which technically, relative to the equator is the north.My mini arrived yesterday and doesn’t work from my balcony facing a big north sky ( but with a balcony floor above), so it needs a fairly open space. Didn’t want to dangle it out from under the upstairs balcony incase I dropped it! Will try from my van next week.
Below is a map of the current set of starlink statellites relative to the UKMy mini arrived yesterday and doesn’t work from my balcony facing a big north sky ( but with a balcony floor above), so it needs a fairly open space. Didn’t want to dangle it out from under the upstairs balcony incase I dropped it! Will try from my van next week.
Just to clarify… Do people generally just set at up the kit on the roof/rack when stationary and using the internet or does anyone actually have it permanently installed on their van?
Me tooTechnically the roam plan does not allow in motion use (but some do it). To use motion roam you need to subscribe to mobile priority.
That said on my van I only mount the dish when parked up as I have a 5G router that works most of the time unless in remote locations.
Me too
Interesting.....does that give PoE direct to the dishy?I’m seriously considering upgrading my router to a Peplink BR1 Max Pro 5G. Native Starlink support (they worked with Space X to implement) and with fusion connect it will balance both 5G and Starlink to ensure smooth connectivity when video calling etc. but the router is pricey.
I'm running a Teltonika RUTX50 (5G SIM x 2) with a Yaoshang 3in1 Starlink PoE injector which seems ok so far.
Yeah, not cheap like you said. Can't see me changing what I have in the Cali but could be useful for some of my clients.![]()
Multi-Starlink Bonding with Peplink SpeedFusion | Peplink
Peplink SpeedFusion turns multiple Starlink connections into gigabit-class bonded connectivity for maritime, mining, energy, and construction.www.peplink.com
Try different options as they are relatively good at picking up satellites.
I’m in London so this is my North. I managed to connect just outside the block of flats with sky above. More enclosed at back of my flat -but I didn’t buy it to use it in London anyway!Technically the roam plan does not allow in motion use (but some do it). To use motion roam you need to subscribe to mobile priority.
In the UK the £50 per month 50gb plan allows you to use it in motion over 10mph. The £85 unlimited plan does not! I guess they assume that if you had that ability on the unlimited people would just leave it connected all the time and eat tons of bandwidth?
My Mini arrived today and I’m waiting on the magnetic mounts from Tactic Vans and I’ll try it in motion and see how it goes. In reality I don’t see that being a typical use case for me but useful to know that it is an option!
I think the mini is great for casual users like myself, I don’t have the room or electrical set up to run the standard version. However if I were working in the van 4-5 days a week like you are I totally agree the standard version makes more sense.I get that the mini is the new thing. But I still much prefer my standard actuated (motors) with the Yaoshang kit to use my router. Today I was parked near trees and over some time the fish adjusted itself for the best signal even though there were obstructions. That, and with the standard and roam there is no limit for 50Chf here which is about 44 pounds a month.
The mini uses roughly the same power. How have you done the 12v conversion? I assumed you were running it from your Ecoflow?It’s using 30-50 watts over 12v.The mini uses roughly the same power.
