s2bear
May ‘22 - had Bilstein B14 Komforts installed (Hunter aligned etc)
Jan ‘23 - returned to installer to adjust UP as the rear had dropped noticeably since install.
Aug ‘24 - same thing again - noticeable drop since last adjustment and noticeable Neg Camber as a result which ruins tyres.
Result - There was only 5mm upwards adjustment remaining so that’s been maxed out but the setup has already completely sh*gged the NSR Tyre inside shoulder. That’s about 10k miles for the knackered tyre & 22k miles total on the coilovers.
The camber is less pronounced now even for that 5mm adjustment, but still visible.
The wear was exacerbated by the fact that I’d left my winter tyres on instead of changing to summers in May - I broke my hand with the power wrench back in December, didn’t realise so didn’t get it set, went snowboarding, leaned on it, now it’s wonky and painful so rather than revisit that I figured I was only going to be doing around 3k miles or less over summer and I could live with that - but the camber has been bothering me.
Outcome: supplying dealer is now liaising with Bilstein UK (who say this is not a common issue) and are pondering a solution.
This also supports [mention]sidepod [/mention] comment in an earlier thread about weighing the corners when setting up. Suspect NSR has been battered because of road camber AND that’s the Gas and Water corner (although most of the time I’m not loaded up)
Interesting things- with camping gear on board (driveaway awning , cadac, gas and all the little bits that we carry) but not luggage passengers or water, the rear axle was coming in at 1410kg with the rear bench forward and 1,440kg with it in the rearmost position. (1,560kg is rear axle max permitted weight)
So if anyone cares - moving the rear bench forwards so the back is level with the sliding door takes 30kg load off the rear axle.
I haven’t, as my children are light, but I can imagine it’s really easy to overload the rear axle if you add adults, water and, bikes to the towel holder!
Now I’m considering going back to standard suspension with maybe some 18” General Grabber AT3 for all year round as I’m not sure I can be *rsed with this anymore and that will allow me to focus 100% of my negativity towards the saggy roof issue
but I probably won’t fit in the car park where I go snowboarding.
Thought this may be of interest to anyone considering B14 Komforts which, apart from this, have been ok. Will update the thread if Bilstein come back to me.
2022 204 4Mo DSG OCEAN
