wildslammer22
You have a very persuasive case and I can see myself following in your footsteps.
I too, like the idea of not having to use EHU on a campsite, particularly as some sites seem to pluck the additional cost of EHU out of the air.
What battery make have you gone for, by the way?
My 100/20 MPPT is also Victron connected to 3x100w panels fitted by Roger at SCS.
The only doubt I have is that, in my early days of ownership and in my research period, I think I read that the 6.1 control panel wouldn't recognise LifePO4’s and would therefore pose a problem. I'm not sure if I dreamt this, though. And I'm not sure if this has been overcome yet. Time for some updated research, perhaps.
I went for the Xplorer Polarmax 100ah batteries. They seem to have a good spec and my installer has used them and recommends them. There are a few options that use the same or very similar case size as the LA80’s. Some cheaper and some nearly twice as much. I was advised to avoid the cheap batteries as the BMS isn’t as good, aren’t self heating, have no Bluetooth connectivity and it’s unlikely that the cell quality can be verified as you get a much shorter warranty. The Xplorer has a 10 year warranty, uses grade A cells and the only thing I can see it doesn’t have that the most expensive options offer is auto balancing. That shouldn’t be an issue though if installed correctly.
I have a T6 so can’t speak to the compatibility of the control panel on the 6.1. I’ve assumed that I will lose the battery indicator on my panel but I figured with the Bluetooth connectivity and the Victron app I can live without it. I will update you after install though if it does still work.
