Jude
Under the seat on my Grand California 2020 model I am sure I found the voltage converter. It has two plugs. A white and a yellow. The white appears to be connected to the socket on the side of the seat with two wires. The yellow is definitely connected to the battery. Problem is that even when connected to the mains power the battery doesn’t charge and there’s no power in the socket. I looked and found a wire with a kettle plug lying loose under the seat. It has 220v when the mains is connected to the van. I can see nowhere it should plug in. What’s going on?
I looked in the electrical cupboard. Mains in from external to the switch panel and multiple mains going out. No charger or voltage converter there or below.
The unit under the seat has cooling fins so I’m sure that’s it.
Can anyone help a nomadic, somewhat elderly, solo traveler?
