Is this hydraulic fluid leaking after loosening screw post roof issue?
DOMINICGG1234
DOMINICGG1234
Chichester
T5 SE 140
Hi all
Ongoing issues in Belgium. Had recovery out to sort roof. They unscrewed the screw to release the roof and strap it down but now noticed this leak. Is this the result of loosening that screw or something else? Front right
is it oil or water leaking ?
Hard to tell. Are we looking at the back of the front wheels? If so it could be hydraulic fluid. But if thats the front spoiler area the fluid is likely coming from another source (too far forward from the hydraulic pump above the rear view mirror)
Not if the hydraulic ram seal or pipe has gone. Fluid would leak and run down front roof drain.
I imagine that fluid isn't going to do the paint finish any favours, especially over a prolonged period. Best to make sure it is fully washed away to prevent damage.
