Do you have anything connected to the load output?I have mine set on ‘Battery life’
No nothing connectedDo you have anything connected to the load output?
No, but I notice the load output is selected to ‘on’ when I use ‘Battery life’Do you have anything connected to the load output?
Thanks, reading the manual it looks like this might change the behaviour of the controller? We had a really sunny day yesterday and the batteries weren’t charged to 100%, which made me wonder…. Has this something to do with the settings.What you have posted is the Victron algorithms for the operation of the load output terminals.
Assuming you have AGM batteries the charge setting "AGM spiral cell" preset does a reasonable job.
The same here, just trying to figure out what is the best way to get the most out of the solar panelNo, but I notice the load output is selected to ‘on’ when I use ‘Battery life’
Tbh I only use this setting because I read it on here somewhere![]()
What are you using to gauge how charged your batteries are?weren’t charged to 100%
The Victron Connect app and the display in the Cali. It was showing 70% and 12.3 VoltsWhat are you using to gauge how charged your batteries are?
Maybe the fridge is taking a lot of energy when the sun is shiningI have only had the solar panel for 26 days now however the fridge is on all the time and only a few short drives…… batteries have not shown full but do stay well charged
Hi, just changed this setting to always off and noticed the batteries getting more charged now. Curious to see how this worksI don't have anything connected to the load output and set mine to Always Off.
Thnx, it seems that when set to always off the batteries are getting more charged. It is still on ‘bulk’ although the head up display shows 100%. Maybe the values need to be tweaked a little, but that’s something that I have to keep in mind for later.I also have a Victron Cerbo GX and this allows me to monitor remotely and have different views of current flow and logs. I have 4 MPPT’s and with them all set to Battery Life I saw some strange behavior like negative power at night (small like -2 to -4 watts). Setting this to Always Off eliminated that. Was making me mental trying to figure out how it could possibly show negative watts from solar.
