CampervansScotland
Hi, just wanted to give everyone a heads up on a fridge issue which has caused us a complete nightmare
fridge mechanism failed on closing the fridge. This is a design fault as the mechanism relies on a lever pushing down on a bolt (threaded) the obvious failure is the more this works on the bolt the more the bolt loosens. Sounds minor right? Wrong!
if this happens on closing the fridge will be locked with absolutely no way of opening other than smashing off the front panel. After a series of mechanics and technical experts from VW looked at this they resorted to smashing the door into pieces as the only option. There is genuinely no other way to open. It is worth regularly taking the front panel off and checking the bolt security in the open position to avoid a complete nightmare.
I’ll post some pictures shortly
