California Rob
Thats good to know..There must be some tolarance in wheel size purely because of tyre wear 8mm down to 2mm must make a bit of difference.I've used mine & not had any problem with the ABS light.
You have to reset the flat tyre indicator that was triggered by the initial flat. As long as the rolling circumference of the replacement is the same or very close to the other wheels there shouldn't be any warning lights.
