Which rear light cluster.
Georgeo
Georgeo
Paisley, Scotland
T6 Beach 150
Just found a large crack on the side of the rear light cluster. So need a replacement. But which version. It is a 2019 Beach. See image. Any help appreciated. Also I don’t think you can get the Lens alone. Is this correct?
If you remove it there should be a VW part number on the inside.
Thanks will do. Worried it will come apart but I guess a bit of glue will hold it.
Just put some clear tape on. Will keep water out until replaced.
