Water tap = fuse blowing
Tom Smith
Tom Smith
Ashton u Lyne
T7 California Ocean 4 Motion
I have a very frustrating problem with my tap.
It stopped working, so i changed the 5amp fuse twice and they both blew.
I tried a 10amp fuse and the tap works perfectly.
So the tap works and the pump works, but i know I shouldn't be using a 10amp fuse.
Not sure how to proceed.
Has anyone had any similar experiences?
Or could offer some advice?
Thank you.
Could be the pump is losing it and drawing more power than normal .
If a fuse blow and you change it with a stronger one and continue using it you'rlooking for trouble.
Thank you.
High resistance in tap or pump. Probably pump.
Check the pump..
Put the 5 amp fuse back in. Remove cutlery draw in R hand kitchen cupboard.
From the bottom of the tap trace the wire around the R hand side of the sink to a foam covered connector. Unplug the connector. Switch the tap On and then short the connector ( not connected to the tap ) with a paper clip. Pump starts OK? Or if it doesn’t check the fuse. If the fuse has blown then Pump needs replacing as it’s seizing up.
If the pump runs OK and fuse is OK. Then reconnect the tap and switch on the Tap . If fuse blows then high resistance in tap microswitch ( unlikely but possible ) so either repair or replace tap.
Check the pump..
Thank you for this advice, I shall try this.
Much appreciated
Check the pump..
My fuse keeps blowing.
How do i figure out if it’s the pump or the micro switch in the tap?
The pump runs fine but is very old now.
As above basically. If removing tap from circuit and starting pump by completing circuit in plug with paper clip and fuse then blows - Pump.
If fuse only blows when tap is in circuit switching on pump then - tap.
If fuse blows both times then short circuit in wiring.
Azteccamper
Janno
Janno
D
Denzilgts
Denzilgts
Lalala
8K
cpjb@btinternet.com
cpjb@btinternet.com
mountainman
